Solid Edge ST8 Standard Parts SQL Server Error
Im having an issue with the Standard parts not opening. it comes up with an SQL error. I have a commercial version of ST8 and have loaded it onto my local PC (Windows 10).
Everything used to work fine but one day it decided to stop and I have not been able to get it running since.
I have tried to repair the installation using the DVD provided and I have removed the install and run a new install. Still no luck
Ive read the "Solved" post in this forum which didnt really tell me anything i didnt already know. The error number is error 26
Any help would be appreciated
Cheers
Dean
Re: Solid Edge ST8 Standard Parts SQL Server Error
Solution Partner Builder Solution Partner Builder
Hai,
have you try to setup inside the SQL server configuration manager?
error 26 says that some program cant connect to your SQL service.
Try some tips from links here:
https://www.youtube.com/watch?v=h24S8xXC94A
https://blogs.msdn.microsoft.com/sql_protocols/2007/05/13/sql-network-interfaces-error-26-error-loca...
Ota
