Solid Edge ST9 Certified Professional Badge Status.
Hello, a few days ago I got the professional certification of Solid Edge ST9, why does it even change my badge status? Both the community account and the certification account, the emails are the same. Thank you and sorry for the inconvenience.
Certificate ST9 AI(Revised February 2017).pngSolid Edge ST9 Certified Associate ICertificate ST9 AII(Revised February 2017).pngSolid Edge ST9 Certified Associate IICertificate ST9 Pro(Revised February 2017).pngSolid Edge ST9 Certified Professional
Alberto Pérez Parra.
Mechanical Engineer.
Re: Solid Edge ST9 Certified Professional Badge Status.
Hi @AlbertoPP
Congratulations !!
You have to contact the Administrator Laura regarding this.
regards,
Arek
This is the first I've seen of the different associate I, II and Professional certifications.   Is there some addtional infromation on these classifications?
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
@kjoiner the Solid Edge Certified Associate Program is intended for academic users. There are two levels of certification for academic users:
  • Associate Level I – Aimed at high school students
  • Associate Level II – Aimed at college and university students
The Solid Edge Certified Professional Program is intended for any professional user.
More on Solid Edge Certifications can be found here:
https://www.plm.automation.siemens.com/en/products/solid-edge/certification/
Thanks Dave,
I have always taken the Professional exam so I wasn't sure if there were new incremental tests etc.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Excellent, status Changed. Thanks SIEMENS Community.
Thanks, issue solved.
Good Afternoon Alberto Pérez Parra!
How I visualized who you are well experienced in SolidEdge certifications.
I am from Brazil and am having divergence in my solidEdge certification, If it does not disturb you, could you help me? It refers to the value imputed in the response box.
Calculation of volume:
Result shown on solidedge:
I put the value in the answer box: 1620426945.
Distance:
I put the value in the answer box: 18096.
SolidEdge says that it's wrong
I was disapproved twice for this divergence, could you tell me what would be the correct value as the example above?
Att,
Wendel Trento
Hi there @WendelTrento,
Looks to me like you have only missed the decimal point in both of those results......
  • 1620426.945
  • 180.96
Hi @SeanCresswell
Hi @WendelTrento
and as far as I rememeber, YOu only should enter the integer values of these results.
So IMHO I believe You have to input:
  • 1620426
  • 180
what is a little bit strange to my feelings, but it was, as I can remember
Wolfgang
