Solid Edge STEP translation problem
Hi there,
I'm trying to open a STEP model from a supplier. Normally no problems. However now with ST7 MP2 I get this pop-up
Never seen this window. How can I fix this?
Note: I have placed my own templates in the local folder
Note 2: Other STEP files have the same problem
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Re: Solid Edge STEP translation problem
Esteemed Contributor
Hi Daniel,
Not seeing that error here.......can you share an example file?
Your template folder dosen't contain default template files (.par; .asm...) what was selected at installation by you. I use iso metric templates and If I move them I will get same message! Smiley Wink
You can modify this under Application Button - Solid Edge Options - Helpers!
I hope this help!
BR,
Imics
Sorry for the late reaction, it seems that it's the solution.
The STEP file doesn't matter, had the same problems with other STEP/IGES/parasolid files.
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
