Solid Edge Subscription Question
Greetings,
I was wondering if there are any other folks using SE on a subscription basis or if anyone knows if subscriptions can be ungraded mid-term.
I ask because I renewed my annual SE Foundation subscription at the end of January. Now it appears that I may need some analysis capabilities on an upcoming project and I wonder if I can upgrade my subscription to a Premium license. I sent an email to customer service, but they didn't seem to understand the question.
I thought I would check in here before I tried calling. I was hoping I could just upgrade and pay the prorated difference between the two subscriptions when I request the upgrade.
Bob Henry
REH Technical Consulting
Canonsburg, PA 15317
Re: Solid Edge Subscription Question
Bob,
(I believe) you cancel your current subscription and start a new for the second product.
Normally your reseller/VAR/Sales should be able to help you out with this. I believe you have a VAR?
Also answer on how the payment & difference are handled in this case.
Good luck!
/Ulf
Siemens EMEA GTAC Support
