Solid Edge Symbols meanings?
looking for a document similar to this Solid Edge Symbols but for the latest version.
I have a blue diamond next to my part in the assembly path finder. what does that mean?
MagRiz
(ST9 User Est 01.18)
10 REPLIES 10
Re: Solid Edge Symbols meanings?
Blue Diamond means the body is grounded. (By grounded it is meant that the body is constrained , i.e the body does not have any degree of freedom)
I will attach the meaning of all the symbols soon
A grounded relationship as you are describing is basically the part is locked down, in whatever location it currently is at, and cannot be moved. Usually this is something that was either placed automatically when a part is created in place (if you have the autogrounding checkbox checked when creating in place, or sometimes when an assembly is translated from another format, or also if you drag and drop a part into the assembly while holding down ctrl. When you hold the ctrl key what it is basically doing is matching the coordinate system of the part being placed withthe coordinate system of the assembly, though it places the part as such, but just creates a grounded relationship.
So basically when you see that symbol, it means you can't alter that parts location unless you supress or delete that grounded relationship.
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
The help files have legends for the various symbols. Looking for Assembly Pathfinder icon descriptions? Look in the Path Finder in assemblies help file.
Attached files for the meaning of the symbols in assembly environment
Thanks, out of interest, is that list you complied or can i find this on SE?
MagRiz
@MagRiz
I found it inSmiley FrustratedOLID EDGE HELP
Can you send a link of it so i can get a clearer image - id like to print it.
MagRiz
Hi @MagRiz
search for "assembly pathfinder symbol"
This find the appropriate page of help
