Solid Edge Teamcenter integration get Last Modifying attribute
I hope I'm posting the question on the right forum.
I want to get from Teamcenter and on the SE draft template two attributes: Last Modifying User and Last Modified Date.
So I created mappings file with this values:
"Last Modifying User": ItemRevision.last_mod_user /master=iman /description="Last Modifying User"
  "Last Modified Date": ItemRevision.last_mod_date /master=iman /description="Last Modified Date"
Last Modified Date works OK but Last Modifying User value is not added to draft properties.
Does somebody have some experience with this?
6 REPLIES 6
Re: Solid Edge Teamcenter integration get Last Modifying attribute
Try to get them directly from a SE Draft dataset, this should be more correctly solution.
        "Last Modifying User" : last_mod_user /master=iman /description=Last Modifying User
        "Last Modified Date" : last_mod_date /master=iman /description=Last Modified Date
SE ST9 + TC 10.1.7
Unfortunately it did not help. Still the same problem.
Date is updated but the user is not.
In TC this attribute is filled or blank ?
SE ST9 + TC 10.1.7
Yes it is filled.
Try this:
"Last Modifying User" : last_mod_user.user_name /master=iman /description=Last Modifying User
I think that should work
SE ST9 + TC 10.1.7
It works! Smiley Very Happy Thanks for the help.
