Solid Edge can not open
I can not open my Solid Edge, when I open just show Server Busy as picture shown bellow
I tried to uninstall and install again but can not solve
Please help us to solve this prolem
Re: Solid Edge can not open
I click the Switch To button normally when this prompt appears and Solid Edge is then visible on the screen, although I don't know why this happens.
I tried to click Switch many time but can not changed
I would guess you are best doing a full uninstall, then remove any registry entries as well as residual program folders. Reinstall (run as admin) and disable you anti-virus while doing so.
CAD/CAE Manager
ST8 MP9
Did you happen to also install the Solid Edge Viewer?  The 2 are not supposed to be installed on the same PC and doing so will break the Solid Edge installation.
http://Grundey.blogspot.com
Thanks for your help! Maybe one problem relevent to MS office When i uninstall and reinstall MS office, after that I open Solid Edge running nomally
