Re: Solid Edge classic hose in assembly.
HI
Thank you for trying to help.
Attached is a video of my problem.
I want to animate opening cabinet door, and there is a hose between the door and the cabinet.
I have ended my subscription of SE and want to see what I'm doing to do and which software to use.
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
HI @centernorway
this is a matter of a Adjustable Tube, which came into SE at a practicable type in SE2019
So if possible, then You should update to SE2019 with xPresRoute
Wolfgang
HI
Thats a nice feature.
Thanks for information.
Will se if I upgrade to premium or choose another software.
@hawcad  Do you know which version of SE is required for that functionality?  I assume xPresRoute is an addon and it would require some minimum level?
Thank you.
If you cannot find a Solid Edge setting, confirm you have a file open of the type that will be affected.
Hi @bnemec
SE2019
Wolfgang
so xPresRoute addon will work with Foundataion, Classic, etc.?
Hi @bnemec
I know xPresRoute as addon to Classic so far, what IMHO makes sense too.
But it should work with Foundation too and is included in Premium
Wolfgang
Thank you sir.
