Solid Edge crash after simulation
Hi guys,
My solid edge crash after i close the results of my simulation. This happen when i manually adjust the colour bar for safety factor.
Is there any solution to fix this?
Thanks in advance!
Re: Solid Edge crash after simulation
Syamim,
best is to report this to your Support (reseller or Siemens).
If possible to reproduce they will log a Problem report, if not they try to solve your issue.
I don't believe this a general issue.
Regards /ulf
Siemens EMEA GTAC Support
