Solid Edge hobby licence
Hello all,
I have a question, is possible some where download solid edge for hobby with free licence??
I found only free version for students on some schools, but i´m not student only like a learning new things (autodidact)
I know that is a free version for 45 days, but i need it for the longer time..
8 REPLIES 8
Re: Solid Edge hobby licence
I'm afraid not. There is a start-up program, where you can get a full licence if you are a new start-up company but it's not really for hobbyists.
I believe that some companies licences allow use at home as well, but I get the impression you do not use it for work.
@Budwarek There is no hobby version of full Solid Edge, only the "Free 2D / 3D Viewer".  If you join the Local Motors "Launch Forth" group, you can download a Launch Forth edition of Solid Edge from them legally.
https://launchforth.io/tools/
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
@KennyG that's a great tip, I hadn't heard of that program.
Hi @KennyG
great info and intro.
But can You explain in few words, what the idea behind that project is?
Wolfgang
@hawcad @Budwarek @Alex_H  Launch Forth came from Local Motors as the crowd sourcing part of it and as such handles all the organization and planning for a variety of projects but it also appears that they have expanded Launch Forth to do other projects for companies other than just Local Motors.  As a member, you can contribute your expertise in a variety of disciplines towards the project goal.  They have a method of scoring contributions and based on that there is some compensation ifor accepted contributions in the way of prises I believe.  There are a whole array of projects Launch Forth is working on...
https://launchforth.io/discover/
@KennyG  I get it right?? If we add to this community, we can use solid edge free. Other people in this community working on some projects, and have some rewards from that.
We will not working on any project, but nobody will not know it. So we will not must do anything, pay anything if we not like to do.
Or is there some problem, some check what are you doing in solid??
You have an option on the student version that says "Self -Taught".
@Joanpolo but what you write to academic boxes?
