Solid Edge - problem with license
Not applicable
Hi, currently I downloaded the software from your side, after completing the installation program "Solid Edge License Utility" wants me to show him your license. The e-mail I learned that the license file is attached in the Annex. But in the email you receive after signing up as a student did not receive any attachment. I would ask for help, Regards Adam
Re: Solid Edge - problem with license
Not applicable
There will definitely be an attachment with the welcome email. Failing that, I would suggest filling out the form again and getting another email which will hopefully have the license you need!
Cheers, Iain
[langtitle=de]Re: Solid Edge - problem with license[/langtitle]
Not applicable
since attachment is in textform your mailclient might show you the licence-data at the end of the mail (like thunderbid does ;-).
regards Norbert
