Solid Edge st 9 Student Edition
I try to  download solid Edge st 9  Student Edition but get the  download Solid_Edge_Student_ENGLISH_ST6_32Bit.exe
5 REPLIES 5
Re: Solid Edge st 9 Student Edition
Hello Ed2,
I think you need to contact with any VAR of Solid Edge in your country, or with LauraWatson
Student license file for ST9 will launch ST6.
@JakubK,
If I understand correctly...... @Ed2 is trying to download ST9, but the file link on the Seimens server, is pointing to the ST6 executable file. Clearly an error on the server side.
YES
so when I am go get the download?
I am not sure how you signed up to get the download ink, but I just signed up to test it out and I am getting the ST9 download without any issue.  I would suggest considering registering for the student edition again.
