Solid edge ST10_frame generator problem
Last time I have found a problem with creating of frame. To create a frame I use own prepared profiles. Everything worked perfect in St9, now I have problem in St10. I don't know what is the reason?
Enclosed please see video.
bros
Re: Solid edge ST10_frame generator problem
Builder
Builder
I assume you are expecting the SHS to populate along the length of your sketch?
Have you tried to reproduce using the SE OOTB frame parts instead of yours?
Phil
ST9
WIN 7Pro 64bit
DELL T5810 3.7-4Ghz 32Gb ECC
Betreff: Solid edge ST10_frame generator problem
Hi @brosscorp
can You upload the farme profil to the forum?
Just from the vieo casn't be seen any failure with the profil part.
What happens if You have more than a single line in the ASM sketch?
Will it work correctly in that case?
Wolfgang
