Solid edge error
Hello..
How to resolve this error in Mold tooling in ST9?
Regard..
Richard.
4 REPLIES 4
Re: Solid edge error
MLombard
Retired
If you haven't done it by now, you should contact GTAC or whoever provides your support. There isn't really enough information here for anyone to diagnose the problem. We would probably need the model and some system specs to be of much assistance.
What Matt said and is it repeatable after rebooting your pc?
Bruce Shand
Hi, I have the same problem, could you solve it and run mold tooling? What is the solution?
EXCEPTION caugth in commands.cpp@3556:
EXCEPTION mpfstd_fail_ProgramError:
mpdbalgo_MbPlateTypeMgr::Init : tipochapa.dat file not found
David G.
Richard,
if you haven't received any answer yet, please check out my answer to this post in this forum.
