Solid edge sheet metal Query
How to merge the sheet metal which comes in the curved path.
9 REPLIES 9
Re: Solid edge sheet metal Query
Hi Sandeep,
I don't follow....can you provide some more information [and/or a picture] for what you need to do here?
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
Thank you for the reply. I want to merge the two sheet metal along a curved path. Please find the attachment of image file.
You will have to delete the bit on the bottom and create a new flange off the top.
Thank you. But how to create a flange at curved region.
I have attached the solid edge sheet metal file of the same.
Here's one way to do it. I took your model, deleted the top flange, and extended the front wraparound flange up. I then drew a sketch at the angle I wanted the top flap to be at eventually, and made a normal cutout across the entire wrapped front flange. I added the top flange and set its extent to the edge of the front flange, and then simply added a corner radius. Below are the steps in pictures, and attached is the edited model.
-Dylan Gondyke
Thank you very much Smiley Happy
What has been shown by Chally72 is a perfect solution! Good job!
I think "the life" will be easier in ST7 with the new Part to SM command! Smiley Wink
BR,
Imics
