Solid edge viewer ST6 - simplified reps
Hi everyone,
like you all know, I'm still on ST6, but I discovered the other day a problem with SE viewer.
If I open parts on my computer there is no problem. But if I open it on a computer on the workfloor with SEV, I'm not able to display the asm as designed. I have done the following... I have opened files as simplified, last saved..etc. But I always see a simplified asm on the screen. But if i open it on my own computer with the SEV I don't have any problems. I suppose there is a graphics issue or I have to set the correct setting somewhere somehow. But I'm out of inspiration at the moment. So I whas hoping someone does know the solution for this. Or is this a bug.
BTW the assemblies are FOA's (Family of assemblies)
Dirk Rutten
Dirk Rutten
Solid Edge STX user
Re: Solid edge viewer ST6 - simplified reps
Okay, Nobody seems to know why this occur.
Dirk Rutten
Solid Edge STX user
