SolidEdge Draft Detail Drawing View
I am creating a draft of an assembly and hae used the Detail drawing view tool to draw a circle and magnify the area in the circle to an annotated detail window.
Is there a way to join the top and bottom of the circled window to its origin to show the path of magnificaiton?
Re: SolidEdge Draft Detail Drawing View
Esteemed Contributor
If I understand your question you have to manually add connecting lines or arcs. That would be a good enhancement if there were settings so the software could do it.
Bruce Shand
