SolidEdge no more printing on plotter
My solidedge no more print on our plotter HP DesignJet 500 Plus 42 If I print from SolidEdge to another printer it works. If I print a pdf (Adobe Reader) to the DesignJet 500 it works.
Only SolidEdge is no more printing on it.
I tried reinstalling windows drivers.
I tried changing printing preferences
no way.
Even if I print an A4 page with few things it seems lost. Windows doesn't give any error, and the plotter never move.
Any suggestion?
Re: SolidEdge no more printing on plotter
At this moment, one of the related solution is here, you can try this out:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/I-can-t-print/m-p/409478/highlight/...
The solution is for ST9 so you may have to check/replace it with your Solid Edge version numbers.
On my installation of ST8 this key simply does not exist, I would still recommend this since the symptoms appear similar.
