Solidworks exploded view in Solid Edge
Hi all,
Have you tried to open a Solidworks assembly with an exploded view? Is it imported? Can it be used in Solid Edge or is it just ignored and must be recreated in the ERA environment?
Re: Solidworks exploded view in Solid Edge
Please, can someone tell me what happens to an exploded view in a SW assembly when opened in SE?
I just tryed to import a Solidwork assembly that I believe contains an exploded view and it is loaded in Solid Edge without any "explosion".
So in believe Solid Edge is not able to import the "Exploded view" at the moment.
Hi Fiorini, thank you for the quick answer. That is what I expected but just needed to confirm it.
Again, thank you. Best regards.
