Sounds Solid Edge
N/A
Is there a way of putting sound in documents.
Crousie
Re: Sounds Solid Edge
You might be able to use insert object to embed a sound file, but solid edge will not play it. You can double click it to play it in whatever app you have set up to play the file.
Sent from my Motorola Electrify using Tapatalk 2
Production: ST10 MP6
Testing: SE 2019
