Special helix Inquiry
Hi Edgers,
I need your help how to set up a helix command to achieve what you can see on the attached picture,
How to set up this angle to the helix cut command?
Arek
Re: Special helix Inquiry
Arek,
this is a multiple thread, you need pattern or a sketch with several grooves.
Gerald Haberl
Hi @Gerald,
thank you very much for help,
I will look at your attachment very soon,
Arek
