Square Part to be Patterned Along circular curve
I am trying to pattern a rectangular part around a Curve and i am not getting the desired result about the curve.
I even tried using the curve chord option in ST8 but still i am not getting the desired result.
It would really be great if any1 can help me in this regard.
I have attached the files for reference.
The spacing between the holes of two rectangular parts wuld be 15.88mm.
I am not able to attach my assembly file hence i am attaching an image of the result  i got.
Balaji
Re: Square Part to be Patterned Along circular curve
Hi there,
Can you provide the assembly file that contains the curve you are trying to use for patterning....or a screen capture.
Testing: Solid Edge 2019
TY for your reply.
I already attached a screenshot of the result i am getting.
When i attach the assembly file i am getting the following error
"The attachment's temp.asm content type (application/octet-stream) does not match its file extension and has been removed.
Try to ZIP the file up....
This video might be of use to you though....[not in English though, but easy enought to follow]
...or this video....
TY SeamCresswell for your help
I will try the methods mentioned in the video
Unfortunately, you cannot use the new "Chord length" option here because of holes' distance.
But you can solve this in "three main steps".
Here is a video:
BR,
Imics
Thank you so much Imics.
You helped me learn a lot of new things in solid edge i wasn't aware of.
Thanks a lot for the video you made, it was very helpful.
I am getting the result as expected thanks to you.
Now my problem is i am not getting a closed pattern.
How do i close the pattern as you can see in the assembly i attached in the end it dosnt have value of 15.88mm.
Your help is much appreciated.
Balaji
Your model is almost perfect! Smiley Wink I suggest using goal seeking for what you want!
Here is a video about steps:
BR,
Imics
