St4 radial menu
I find that the radial menu pops up to easily compared to V103. I don't use it. I use the RMB with Ctrl/Alt/Shif keys to move around. How can I disable it?
Re: St4 radial menu
Siemens Master Siemens Master
Siemens Master
Go into the Options dialog and "Helpers" tab. Set the timer to a high value and you should not see it again.
PS> You might find you want to use different shortcuts than RMB anyhow. I never use RMB for view manips. Hover over the view commands to see the most recommended shortcut. Like I use Shift MMB for pan and in ST4 scroll wheel does zoom full time, so I find I need little else than this. if you need Window Area, its ALT MMB.
