St7 borrowed license....
Having installed ST7, I revert back to my normal habit of having a license borrowed for multiple months.
Working on a laptop, this is the most convenient way….
Borrowing the license is no issue; all goes as expected.
Once you (or I) want to start SE, the problems arise.
Starting SE will generate a message box telling you how long you still have (mentioned in days) till the end of the borrowing period.
This box is causing the problem. I’m not able to click the OK button, releasing the message.
It will also cause the message box to appear again and again….. without being able to dismiss the dialogue box.
The reappearance of the dialogue box will also cause multiple SE process to be started.
Has anyone already seen this behavior?
Marc Boom
marc.boom@quayquip.com
www.quayquip.com
