Stagger - confused...
I need your help Guys.
I have to create staggered pattern : 5dia holes - stagger 8 mm.
Can you show me how to do it  please ?
When I am doing this there is an option to set stagger but there is another option to Fill, Fix or Fit the pattern.
Confused.
I thought that when I am setting the stagger, SE will fill all holes to assigned space.....
thank you
Arek
Solid Edge ST8 MP10
Re: Stagger - confused...
Could you post a screenshot about your issue?
BR,
Imics
Betreff: Stagger - confused...
I think what You are looking for is within the option of any pattern type, either fixed, fit or filled
See picture and choose Your preferences:
Wolfgang
