Re: Standard Part Library Installation
Ive seen this happen before.
It usually occurs because while you might have updated SE to a newver version you did not update Standart Parts. Is this the case for you?
Basically you cant just update SE to a new version you have to redo the enstall of the Standart Parts as well.
