Standard Parts Administrator (Teamcenter) won't register parts
I am trying to register a little over a hundred (already existing in TC) Cap Screws through the standard parts administrator via an Excel document.  I have prepared the .par files and properties and make it most of the way through the registration process.  When I get to the final step (7) the Admin runs through all the parts and gives me "!!! Path not Found".  Right now I am working exclusively from my local drive with the intention of adding to TC after the registration.  The configuration wizard Parts storage is set to Teamcenter but everything else is set to local (CSmiley Happy.
  • Do I need to change the Part storage on the Configuration Wizard?
  • Do I need to add an alternate path on the Excel sheet?
