Standard Parts: Preview
It worked but I broke it. The problem is I don't know what exactly I did wrong...
dEeqnFZ
Any idea how I can get the preview in the left column back?
Solid Edge 2019 & AutoCAD 2019 user
Re: Standard Parts: Preview
Hi Joris,
Have you been able to solve the problem?
A repair gave me the preview back, but made me loose the parts.
I needed to populate all the parts again, again 2 hours of PC work.
I can't beleive how bad this piece of software is made, the installation is a disaster, the use is far from user friendly and slow as hell.
I found the solution.
This is because the Standard Parts Configuration Wizard has the specific path where the parts are located. And you should change to the general route.
