Standard Parts-ST8
Hi!
I Installed Academic Version ST8, I tried do assembly with Standars Parts, but I have error, I don't have on my computer SAC files and I can't install SP Administration, beacouse when I click installation ST8 files, automatically turn on instalation ST. How can I resolve problem?
Re: Standard Parts-ST8
Community Manager
@arkamus1994
Standard Parts Administration setup need to install after Solid Edge installation to create a SAC file and Standard parts database if you are working on standalone machine.
If the user is working in domain network then any user (ideally Administrator) can install Standard Parts Administration setup and share the SAC file path to domain users to access the Standard Parts database and use it in Solid Edge applications.
You can find the Standard Parts installation document - StandardPartsInstallationGuide.pdf at "C:\Program Files\Solid Edge ST8\Program\ResDLLs\0009"
If your problem is not resolved with above suggestion then please let us know the exact problem with steps so as to give appropriate solution.
