Standard Parts lib crashes after selecting 3D view for visualization
Good day
I just installed the standard parts library in st8. Everything worked fine until I changed from 2D to 3D view in the settings. Since then, every time that I would start the standard parts library from withing Solid Edge Assembly the program would crash. It does not give me the opportunity to change the setting back to a 2D view. I reinstalled but the problem persists. Any idea how to reset back to the 2D view?
Kind regards
PL
Re: Standard Parts lib crashes after selecting 3D view for visualization
I solved the issue by changing the Regedit Key Value PreviewStyle located at:
HKEY_USERS\S-1-5-21-912929231-124627660-4195695199-1001\Software\Unigraphics Solutions\Standard Parts\Version 108\PartFinder
from 0 to 1.
0 = Preview Style 3D (leads to crashes)
1 = Preiew Style 2D (is stable)
This issue is therefore solved.
PL
