Standard Parts on ST10 with database from ST9
A customer wants to keep the Standard Parts database from ST9 after installation of ST10. Are there specific instructions about the best way to do this? Is it enough to indicate the existing SAC file?
Thanks!
Re: Standard Parts on ST10 with database from ST9
Please see page 6-1 of the ST10 Standard Parts Installation Guide re: upgrading existing Standard Parts:
https://support.industrysoftware.automation.siemens.com/docs/se/st10/StandardPartsInstallationGuide....
I did that, but for some reason the parts were not showing. I had to go to the Administrator and pick the new path in Database > Change Paths, although the paths didn't change. It seems it had to be forced. So I was asking here to check if I skiped something. Standard Parts installation is still a bit cumbersome...
Anyway, can we find somewhere a list of what's been added on the ST10 Standard Parts library? A "What's New in Standard Parts", or something?
