Standard Parts view
 When I open Standard Parts in Solid Edge it shows me a preview of folders with names of S11, S12...
How can I do it to show me the folder with the name of the category?
Betreff: Standard Parts view
HI @xeniaturon
I think this is an installation problem wheer not all install data is brought in correctly or the SAC  file is corrupted.
I would suggest to unsinstall standrad parts and to a new install with admin privileges to see wether it will work then.
Or does the subfolder of the standrad parts installation folder to not have enough right to read them
Wolfgang
Re: Standard Parts view
 I found the solution.
This is because the Standard Parts Configuration Wizard has the specific path where the parts are located. And you should change to the general route.
@xeniaturon  Nice find, good info.
Bruce Shand
