Standard parts Solid Edge ST9 windows 10
Hello.
There is a problem in Windows 10.
Standard parts installed on the server.
When you try to run the standard parts on the user's PC an error occurs that a path to the SMAPINIFile does not specify.
Operating system - Windows 10.
Control - Teamcenter.
SMAPINIFile is located on a network drive.
Re: Standard parts Solid Edge ST9 windows 10
No problems here. Did you run the "Standard Parts Administrator" and configured the database?
Greetings from Germany
Christian Kunkel
https://c-k-m.info
Yes. The database is fully configured.
Everything worked till upgrade to windows 10.
Now, every time a file is accessed, in the settings the link to this file is reset.
