Standard parts
N/A
Hi... are there any standard parts in the trial version?
Becouse when i click on the "Standard parts" icon, it gives an error message.
Re: Standard parts
Siemens Master Siemens Master
Siemens Master
I believe so, but you'd need to install and set up the standard parts. you have to go back to the original install exe and look for the standard parts option at the first startup pages. There is also a document on installing standard parts somewhere in the Solid Edge install folder. If you want to pursue this I can get more info...
