StandardParts not adding in ST10
I was wondering if someone could help me, i have installed Solid Edge ST10 & Standard parts administrator. I have followed the User guide for installing Standrard parts in a Unmanaged enviroment.
All the parts have been added and Generated which took about 8 hours.
When in ST10 i can see the parts but i cant add them to the model.
Does anyone know a possible fix?
Thank you! Smiley Happy
5 REPLIES 5
Re: StandardParts not adding in ST10
probably you don't have the correct license to activate the std parts.
Betreff: StandardParts not adding in ST10
Hi @Abdull
Can You check wether You have an appropriate license and write permissions for the standard parts folder
Wolfgang
I don't know what your problem is about as our system is managed. However, just a comment, you don't have to generate the whole library. You can add/generate parts as you need them.
Bruce Shand
Hi @Abdull
was it a rights problem?
Wolfgang
sorry, it was a licence problem. Didnt know standard parts was an extra item. thought it was just included in the package.
thank you for your help!
