Starting to Assemble Parts
N/A
I have about 100 or so parts to go into an assembly and getting to that step is a little overwhelming. Any thoughts
With this image how do I incorporate to set the parts at the proper placement
http://screencast.com/t/nvhZxZInf
Crousie
Re: Starting to Assemble Parts
Esteemed Contributor
Crousie,
"Patterns" are your friend here....
Streetscape Limited (NZ)
Sent from my Samsung Galaxy NoteII using Tapatalk 2.
Solid Edge ST10 [MP6] Classic [x2 seats]
N/A
I've got the pattern and will not show on the assy. The only way this will work to me is using protrusion to show in the assy.
Crousie,
Judging by your image, you may be coming up against the "Non-Manifold" error with your adjoining circles, where "Two or more faces on one body that are connected at a theoretical point or line
and form a zero thickness edge.
" If this is the case....modify the design to have EITHER a tiny gap or tiny overlap.
N/A
I've added a video to help you understand a little better.
http://screencast.com/t/aX2OhVCndHZ3
