Steering wheel live view on?
Is there a particular setting that turns off live view of the steering wheel's articulations of a part? (Move/rotate etc) ? When I installed SE it allowed you to rotate the part and see it's rotation, now it only gives you an angle but doesn't move it "live" until you click the mouse and set it to an angle. I imagine this is just a setting that was changed inadvertantly. Thanks!
Re: Steering wheel live view on?
I guess you are referring to model edits (move/rotate) and not view manipulation.
In that case, Solid Edge Options - View Tab - Dynamically preview feature creation should be checked ON.
Hope this helps.
Many thanks, just what I needed. Not sure how this got toggled off!
