Stitched surface, no faults....won't turn into a solid
OK. I have created a stitched surface that I cannot turn into a solid. I have used geometry inspector and it says I have no faults. Any idea why this won't create a solid?
Peter Smith
Re: Stitched surface, no faults....won't turn into a solid
When I open it "errors" says there's a parent part-copy missing.
Bruce Shand
I seldom work with surfaces so I'm wondering how does one turn such a part into a solid?
Bruce Shand
I forgot to break the link. Try this one.
Peter
I show non-stitched edges circled in red.  Most likely didn't stitch because of a gap.
http://Grundey.blogspot.com
How did you find those non-stitched edges?
Peter
Used "Show Non-stiched Edges".
Got it. Thanks!
Peter
Again, if I may: how does one turn such a part into a solid?
Bruce Shand
Hi Bruce,
You are absolutely right that we miss the "make base feature of closed surface.
I also can't find a hole or missing surface when stitching and I think the body is closed.
There was one - not elegant but working - way I found.
Create a protrusion somewhere away of Your body followed by a boolean add and everthing together will form a solid body
A following cut can take away the original protrusion.
But it might be not the proper way I would like to say!
Wolfgang
