Stop Auto Revisions
Honored Contributor
Honored Contributor
Stop automatic revision numbers.
Just about every file I have ends in a -6 or - CS or something like that.
ST9 is assuming the last -"whatever" is the revision of the file.
I do have about 20 files I track revisions on. The rest I don't.
How do I stop ST9 from making that assumtion?
Re: Stop Auto Revisions
IDK if it's the same in ST9 but you can try changing the default rev delimiter to a period instead of a dash.
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
Honored Contributor
Honored Contributor
I don't see the "turn off" for revision management.
Perhaps if I use something other than a - or . so it never works.
That would seem useful. Just for shucks, try an up-caret ^ as the symbol. You never use that, right?
Maybe someone with more knowledge on dos and don'ts for revs can chime in here.
Bruce Shand
Betreff: Stop Auto Revisions
Could be You haved turnedon the new ST9 option to automatically add the revision marker and index to the filename.
Turn this option off and it might work as wanted.
Wolfgang
Ah! So there is an off button...
Bruce Shand
Honored Contributor
Honored Contributor
Back to the starting question. Where is the off button?
Here....SE-Options, under the "File Management" group....
Testing: Solid Edge 2019
Honored Contributor
Honored Contributor
So unchecking "Automaticaly revise drawings that use the solected 3D document" turns the automatic revision naming off?
Or selecting the "None" turns it off?
Here is what help offers
Siemens Documentation
File Naming Rules
Automatically append Revision ID
Selecting this option displays the following in the document list:
This column in the document list
Displays
New Filename
The revision suffix, appended to the name of the file. Box is read only.
Doc Number
Displays the current document number.
Revision
Displays the current revision ID. For new files, it displays the initial value, as specified in Options dialog box→General tab.
Use Document Number and Revision ID
Displays
New Filename
The document number, the delimiter, and the revision ID. Box is read only.
Doc Number
Revision
This option is recommended for new users.
Enforce Unique Document Numbers
If the fast search capability is enabled, you must provide a unique document number to new files in the indexed locations.
None
Specifies that you do not want to apply any file naming rules.
This option is recommended for existing users.
When revising documents
Automatically revise drawings that use the selected 3D document
If the fast search capability is turned on, this option automatically revises drawings that use the selected 3D document.
______________________________
It never states what causes or turns off the automatic fill in of revision number when it origionally had nothing.
@12GAGE, the radio button toggles between the selections......as in my image, I currently have ours set to "None".
Auto Append..., [or] Use Doc....  = ON
None = OFF
