Struggling with SE FEA, help please..
Hi all,
I'm really struggling with Solid Edge FEA... Where can I find documentation on how to control the options in FEA? Is there a manual for SE FEA?
I've been using Solid Works Flow Simulation for a few months now, and it's a breeze to use.. but we still have SolidEdge ST7 w/FEA, which is painfully difficult to use. I figure it's because I cannot find any documentation on the software... One big question is how do I load/unload the FEA results? If I have a meshed model, how do I turn off the mesh so that it doesn't lag my computer?
Thanks!!!
"The society which scorns excellence in plumbing because plumbing is a humble activity, and tolerates shoddiness in philosophy because philosophy is an exalted activity, will have neither good plumbing nor good philosophy. Neither its pipes nor its theories will hold water." -- John W. Gardner
Re: Struggling with SE FEA, help please..
ncsteinb,
I would direct you to the Solid Edge help. There each command is described.
If your local VAR isn't performing a training on SE Simulation.
Regarding the Mesh display, I guess you have 'mesh/show mesh on close' set?
Simply deselect this and the Mesh is hidden
Regards /Ulf
Siemens EMEA GTAC Support
Just to follow up on my colleague's input, the ST7 help documentation can be found here:
https://docs.plm.automation.siemens.com/tdoc/se/107/help/#uid:index
With the FEA documentation continued in the above documentation being explicitly located at:
https://docs.plm.automation.siemens.com/tdoc/se/107/help/#uid:index_sesim
