Stuck and confused on virtual component learning, Symmetric Offset command
I am a new user of Solid Edge going thru the tutorials and courses, now working on on Activity: Virtual component editor.
https://docs.plm.automation.siemens.com/data_services/resources/se/108/help/en_US/selfPacedExt/xid10...
I am on step 6, Create the frame from the sketch geometry. The instructions tell me this:
"In Assembly PathFinder, right-click support.par and then click Edit. Choose the Home tab→Draw group→Symmetric Offset command, and enter the values shown."
After doing as the instruction say to edit support.par, the Home tab does not contain a Draw section, see attached screenshot, and the Symmetric Offset command is nowhere to be found on any tab. The instructions go on to tell me to create 3d surfaces, but the only place I have seen the Symmetric Offset command is in 2d sketch mode, on the Offset dropdown.
Re: Stuck and confused on virtual component learning, Symmetric Offset command
Attached is a screenshot of the lesson instructions.
My guess is they missed a step of "Edit the Sketch" or "Create a Sketch".  Doing either will enable your Draw commands and the Offset command.
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
Yes that was the problem. The step missing is to right click on the sketch. select Edit from the menu, offset the highlighted lines, close the sketch, then extrude.
