Sub parts move when using crossing window in assembly
So for a while now I have been dealing with parts moving. When i am in an assembly and i want to move a part or subassembly i often use the crossing window to select it (its a habit). By doning that the part or subassemblies origin changes. this even happens when the subassembly is marked as rigid. the only way i can see to move these parts without changing its origin is the hight the part through the tree instead of using the crossing window.
is there any way to prevent a crossing window from moving the part and not the whole subpart? a real pain, now i need to go into each part and move it back to it proper location....
If you understand what i have been tring to say and know of a way to help, please let me know.
Nathan M. Gardner
Be sure to check out my work!!
Made in Maine Wood Carvings
