Substract feature and assembly mode
I have created a one part of assembly where I have used a Substract feature to cut my part.
These feature I can easily hide in Part mode.
When I try use this part as a assembly part, the hidden substract feature appears and is visible as on attached pictures.
Can you tell me please how to hide this Substract in ASY mode ?
thank you,
Areksubstract 1.pngPart modesubstract 2.pngASY mode
6 REPLIES 6
Re: Substract feature and assembly mode
Right mouse button on the substructed Part.
You have to disable all surfaces and it should work.
Yasser
Yasser,
may I get more precise instruction ?
Is it Part mode or ASY mode ?
In ASY mode it is impossible to do, whole part is being hidden after this operation.
Thank you
In the Assembly mode:
 And if the whole part is being hidden you have to display the Construction Body!
Hi, another solution is to do this in your part.
Just move the Part to Construction, than you don´t have to do this always when you place this part in another ASM.
your solution is the best and desire one !!!
Thank you,
Arek
No problem,
glad to hear that Smiley Very Happy
Greetings Christian
