Super long save time for Simulation Database???
When I close an assembly after performing a simulation, I sometimes encounter a very long save time to save the Simulation Database. I end up terminating the program, because it seems to get 'stuck'... Has anyone else had this issue?
I'm running ST7 Premium with a floating license, saving to our server. Server doesn't seem to be doing much while it is saving the simulation database... :/
Cheers!
"The society which scorns excellence in plumbing because plumbing is a humble activity, and tolerates shoddiness in philosophy because philosophy is an exalted activity, will have neither good plumbing nor good philosophy. Neither its pipes nor its theories will hold water." -- John W. Gardner
Re: Super long save time for Simulation Database???
I am having the same problem.
Especially backing up is taking so long that it is almost impossible for me to use  simulation. I am spending more time for it to save/backup the simulation than it takes me to do the whole thing!
Is there any way of disabling the automatic backup?
