Suppress instances in a rectangular pattern
I'm trying to suppress the middle two rows of holes on this part.  I see the options for suppressing individual occurences and regions, but neither one is working for me.
Your help is greatly appreciated.
Ali
Re: Suppress instances in a rectangular pattern
I've attached a video:
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Bruce Shand
That was great.  Thank you.  I had the right idea, but didn't do it in the right order.
Can I also trouble you to tell me how to suppress individual occurences?
One more question, how do I undo the suppression?  I deleted the suppression box, but the holes that were suppressed are still suppressed.
Pattern workflows can be confusing I agree.
Bruce Shand
When you edit the sketch delete the exclusion box or at least one line of it. The pattern instances should turn green and be regened when you close the sketch.
Edit: Right click the pattern in the pathfinder, left click edit profile, delete a line in the exclusion box, click done.
Bruce Shand
Thank you.  I don't know what's going on today on my computer.  I deleted the hole box and exited out of the pattern menu, but the holes were still suppressed.  I tried again after your respnose and as soon as I deleted a single line, the holes re-appeared.
Same thing with inidvidual suppressions.  Clicking on the green dots wasn't working, but now it is.
Thank you again.  You are always very helpful.Smiley Happy
Meh, it's Monday...
Edit: And...it's PI day.
Bruce Shand
hi @bshand,
i want to check the video that you have share in this thread, but it is not available.
can you repost it or add the link again.
V.Sudheer
Something went wrong with the upload apparently and it's not in my videos anymore. But I quickly created one.
Note that I picked edit definition first but I could have picked edit profile instead.
(view in My Videos)
Bruce Shand
