Surface is transparant
For some reason the surface in this part is transparant. How to make it visible?
BR, Johan
Re: Surface is transparant
This is one of those File Specific Options\Settings that is burried in Solid Edge options.
I wish one day to have Global Options\Settings clearly separated from File Specific Options\Settings.
I also wish the user could decide what options must be Global or File Specific
End of the rant; you have to:
- Open Solid Edge Options
- View page
- Select "Use shadow on constructions" (sorry my SE is localized in italian and may have a different translation)
Many Thanks
@Fiorini    "I wish one day to have Global Options\Settings clearly separated from File Specific Options\Settings."
YES, YES, YES YES!    And we also need to have "SAVE AS DEFAULT" in as many dialog boxes as possible.
And how about "Update Drawing to Template". When openning up a Model from a few years ago to build a new machine, all the parts are stuck in an OLD Template. Why can't we have a single command to update the Part, Assembly, Draft, PSM to the new prefered Template?
Bob
I've checked my options and that is already checked, yet the surface body in my part is still transparent. There is no drop down box under 'Style' to change it either. Any suggestions?
Is it possible to attach the part here ?
