Surface model not displaying in draft
Hello, I have an assembly with imported models that are not being shown in 2D drawing unless go into view properties, find imported part in part list, RMB>include all, select all surface objects and tick "show".
I'd like to know if there's simpler, more optimal solution for showing parts made of surfaces.
Thank you for your time.
Re: Surface model not displaying in draft
I think there no any easeir possibility to do this. There is another possibility: in assembilie you can make PMI View where You will display surface object, and in draft You can choose as active this View.
SE ST9 + TC 10.1.7
