Surface thread
I am drawing a small conical nozzle and need to lay a 1 turn 3mm thread on the upper surface close to the tip. What is the best way to do this?i
Depends on what you need.  In this case it sounds like yo...
Esteemed Contributor
Depends on what you need.  In this case it sounds like you need the physical geometry but there is also a way to do this with attributes for common threading applications.  You will have to do this with the helical feature.  If you are putting this on a conical face, it may be tricky and you will most likely need to use taper on the helix.
Production: ST9 MP10
Testing: ST10 MP3
