Surface to solid from Pro_E translated part
I have a small connector housing that was designed in Pro_e. When I import into Solid Edge ST7 it does not come in as a solid. I have tried geometry inspector, optimize and several import options.
Anyone care to take a look at this and see if it can be made into a solid? I have other components for same project that were able to be imported into Solid Edge from Pro-E.
I attached Pro_E & Solid Edge ST7 model.
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development Emerson Climate Technologies | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA T +1 419 525 8554 gary.dinges@emerson.com
Re: Surface to solid from Pro_E translated part
This is a "typical" non-manifold geometry...
You have to delet or modify "star logo" and patch the hole and...
You can see steps to reproduce it:
BR,
Imics
Thank You !!
Gary
