Sweep Application
With This Video My Attempt Is To Apply A Sweep With A Triangle Unable To.
youtu.be/ZI4VAKbLMUU
I Am Not Able To Send A Video Via Solid Edge From The Web Page.
So, I'm Sending With Out The Http
GregoryLee
Re: Sweep Application
it does not appear that your sketch is perpendicular to the path element of your triangle chosen...
you might have better luck drawing the circle cross section on a plane "normal to curve" of that element of the triangle.  this will assure your cross section is perpendicular to the path.
